Introducción
This guide shows all the steps leading up to, and including, the removal of the motherboard.
Partes
No se requieren partes.
Apply pressure to the back cover and slide it forward towards the camera.
  • Apply pressure to the back cover and slide it forward towards the camera.
  • Lift the back cover off the phone.
Agregar Comentario
Holding the phone firmly, use the notches to grip and lift up the battery.
  • Holding the phone firmly, use the notches to grip and lift up the battery.
Agregar Comentario
Remove the four 4.45mm screws at the corners of the phone.
  • Remove the four 4.45mm screws at the corners of the phone.
Agregar Comentario
Use the plastic opening tool to unhinge the locks around the edges of the phone. Do not worry about the inner components of the phone; they are not connected to this case.
  • Use the plastic opening tool to unhinge the locks around the edges of the phone.
  • Do not worry about the inner components of the phone; they are not connected to this case.
Agregar Comentario
Lift the casing off of the phone.
  • Lift the casing off of the phone.
Agregar Comentario
With the screws removed, locate the antenna.
  • With the screws removed, locate the antenna.
Agregar Comentario
Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
Agregar Comentario
Gently lift up on the antenna and remove it from the back of the device.
  • Gently lift up on the antenna and remove it from the back of the device.
Agregar Comentario
Remove the two 3.50mm screws connecting the motherboard to the case.
  • Remove the two 3.50mm screws connecting the motherboard to the case.
Agregar Comentario
Use the plastic opener tool to detach the three ribbons on the motherboard. Use the plastic opener tool to detach the three ribbons on the motherboard. Use the plastic opener tool to detach the three ribbons on the motherboard.
  • Use the plastic opener tool to detach the three ribbons on the motherboard.
Agregar Comentario
Lift out the top right ribbon from its slot on the motherboard.
  • Lift out the top right ribbon from its slot on the motherboard.
Agregar Comentario
Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing. Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
Agregar Comentario
Lift the motherboard away from the front casing.
  • Lift the motherboard away from the front casing.
Agregar Comentario
After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
Agregar Comentario
Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame. There are three strips total: one on the right, left, and top of the phone. There are three strips total: one on the right, left, and top of the phone.
  • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
  • There are three strips total: one on the right, left, and top of the phone.
Agregar Comentario
Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
  • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
Agregar Comentario
Using the plastic opener tool, remove the speaker from its setting.
  • Using the plastic opener tool, remove the speaker from its setting.
  • Pry where the wire enters the speaker.
  • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
Agregar Comentario
Gently lift the motherboard from the center frame.
  • Gently lift the motherboard from the center frame.
Agregar Comentario
Conclusión
Brayton
Miembro Desde 12/10/11
40 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-13, Regan Fall 2011 Miembro de Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 4,723
