Partes
No se requieren partes.
Apply pressure to the back cover and slide it forward towards the camera.
  • Apply pressure to the back cover and slide it forward towards the camera.
  • Lift the back cover off the phone.
Agregar Comentario
Holding the phone firmly, use the notches to grip and lift up the battery.
  • Holding the phone firmly, use the notches to grip and lift up the battery.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the four 4.45mm screws at the corners of the phone.
  • Remove the four 4.45mm screws at the corners of the phone.
Agregar Comentario
Use the plastic opening tool to unhinge the locks around the edges of the phone. Do not worry about the inner components of the phone; they are not connected to this case.
  • Use the plastic opening tool to unhinge the locks around the edges of the phone.
  • Do not worry about the inner components of the phone; they are not connected to this case.
Agregar Comentario
Lift the casing off of the phone.
  • Lift the casing off of the phone.
Agregar Comentario
Conclusión
Jacob Michener
Miembro Desde 10/10/11
31 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-13, Regan Fall 2011 Miembro de Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 773
