Saltar al contenido principal
Samsung Impression LCD Replacement
Qué necesitas
  1. Samsung Impression LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression LCD Replacement: paso 2, imagen 1 de 2 Samsung Impression LCD Replacement: paso 2, imagen 2 de 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression LCD Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression LCD Replacement: paso 4, imagen 1 de 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression LCD Replacement, Circuit Board: paso 5, imagen 1 de 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression LCD Replacement: paso 6, imagen 1 de 2 Samsung Impression LCD Replacement: paso 6, imagen 2 de 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression LCD Replacement, Keyboard: paso 7, imagen 1 de 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
  8. Samsung Impression LCD Replacement: paso 8, imagen 1 de 2 Samsung Impression LCD Replacement: paso 8, imagen 2 de 2
    • Remove 6 screws holding the silver plate on.
    • 2.7mm in length
    • The keys will peel right out of the screen side of the phone.
  9. Samsung Impression LCD Replacement: paso 9, imagen 1 de 1
    • The silver piece you are left with is the physical keyboard assembly.
  10. Samsung Impression LCD Replacement, LCD Flex Cable: paso 10, imagen 1 de 2 Samsung Impression LCD Replacement, LCD Flex Cable: paso 10, imagen 2 de 2
    • Remove the 3 screws holding down the flex cable.
    • The screws are 2.0 mm in length.
    • The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
    • The keyboard slider frame will come off and the flex cable exposed, but not free.
  11. Samsung Impression LCD Replacement: paso 11, imagen 1 de 1
    • Remove 4 outer screws.
    • The screws are 3.5mm in length.
  12. Samsung Impression LCD Replacement: paso 12, imagen 1 de 3 Samsung Impression LCD Replacement: paso 12, imagen 2 de 3 Samsung Impression LCD Replacement: paso 12, imagen 3 de 3
    • Slide the phone apart, and remove a 5th screw (3.5 mm).
    • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
    • The device will now be in two pieces
  13. Samsung Impression LCD Replacement: paso 13, imagen 1 de 2 Samsung Impression LCD Replacement: paso 13, imagen 2 de 2
    • Lift the tab underneath the blue tape and gently pull the flex cable.
    • The flex cable will now be completely free.
  14. Samsung Impression LCD Replacement, Ear Speaker: paso 14, imagen 1 de 1
    • Remove the single screw.
    • This screw is 2.25 mm in length.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
  15. Samsung Impression LCD Replacement, LCD: paso 15, imagen 1 de 2 Samsung Impression LCD Replacement, LCD: paso 15, imagen 2 de 2
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
Conclusión
Saul Villatoro
Miembro Desde 04/25/11
255 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 4,360
