Introducción
How to remove & replace the phone's digitizer or front buttons
Orient the phone with the screen facing down.
  • Orient the phone with the screen facing down.
  • Using your thumb, slide the back panel away from the camera to expose the battery.
Agregar Comentario
Grip the battery on its sides, opposite the direction of the white arrow. Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
  • Grip the battery on its sides, opposite the direction of the white arrow.
  • Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
Agregar Comentario
Remove the 6 outer screws.
  • Remove the 6 outer screws.
    • The screws should be 3.5 mm in length.
  • Put the screws in a safe place as they are very small and easy to lose.
Agregar Comentario
Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
  • Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • It may help to slide the touchscreen upwards when removing the back panel.
  • The side buttons will become loose and are prone to fall out, so put these in a safe place.
Agregar Comentario
To free the circuit board, remove the black wire that is holding it down.
  • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it will take.
Agregar Comentario
The circuit board will still be held on by a blue and black ribbon that is removed by gently pulling it upwards. The circuit board will still be held on by a blue and black ribbon that is removed by gently pulling it upwards.
  • The circuit board will still be held on by a blue and black ribbon that is removed by gently pulling it upwards.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
  • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
  • The bottom black end cap will snap out.
Agregar Comentario
Remove 6 screws holding the silver plate on. 2.7mm in length
  • Remove 6 screws holding the silver plate on.
    • 2.7mm in length
  • The keys will peel right out of the screen side of the phone.
Agregar Comentario
The silver piece you are left with is the physical keyboard assembly.
  • The silver piece you are left with is the physical keyboard assembly.
Agregar Comentario
Remove the 3 screws holding down the flex cable. The screws are 2.0 mm in length.
  • Remove the 3 screws holding down the flex cable.
    • The screws are 2.0 mm in length.
    • The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
  • The keyboard slider frame will come off and the flex cable exposed, but not free.
Agregar Comentario
Remove 4 outer screws.
  • Remove 4 outer screws.
    • The screws are 3.5mm in length.
Agregar Comentario
Slide the phone apart, and remove a 5th screw (3.5 mm). Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction) The device will now be in two pieces
  • Slide the phone apart, and remove a 5th screw (3.5 mm).
  • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
  • The device will now be in two pieces
Agregar Comentario
Lift the tab underneath the blue tape and gently pull the flex cable. The flex cable will now be completely free.
  • Lift the tab underneath the blue tape and gently pull the flex cable.
  • The flex cable will now be completely free.
Agregar Comentario
Remove the single screw.
  • Remove the single screw.
    • This screw is 2.25 mm in length.
  • Lift the black tab at the end of the ribbon.
  • Gently pull the speaker and ribbon free.
Agregar Comentario
Lift the remaining two tabs and free their respective ribbon cables. Gently pry the screen away from the housing.
  • Lift the remaining two tabs and free their respective ribbon cables.
  • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
Agregar Comentario
If replacing the front buttons, remove the assembly at the bottom of the front panel
  • If replacing the front buttons, remove the assembly at the bottom of the front panel
  • The digitizer is now free to be pulled out from the front housing.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Saul Villatoro
Miembro Desde 25/04/11
255 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 6,590
