Saltar al contenido principal
Samsung Impression Back Speaker Replacement
Qué necesitas
  1. Samsung Impression Back Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Back Speaker Replacement: paso 2, imagen 1 de 2 Samsung Impression Back Speaker Replacement: paso 2, imagen 2 de 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Back Speaker Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Back Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Back Speaker Replacement, Back Speaker: paso 5, imagen 1 de 1
    • Remove the back speaker by carefully prying it upwards with the spudger.
    • The speaker will still be attached to the circuit board by a wire and a small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece at the end of the wire.
Conclusión
3 personas más completaron esta guía.
Ross McKelvie
Miembro Desde 04/18/11
196 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,067
