Introducción
This guide will provide a step by step procedure for installing the keyboard.
Partes
No se requieren partes.
Using your thumb, press down and slide the back cover away from the  camera.
  • Using your thumb, press down and slide the back cover away from the camera.
Agregar Comentario
Remove the battery from the phone.
  • Remove the battery from the phone.
Agregar Comentario
Use a Phillips #00 screwdriver to remove the six 4mm screws. Use a Phillips #00 screwdriver to remove the six 4mm screws.
  • Use a Phillips #00 screwdriver to remove the six 4mm screws.
Agregar Comentario
Find a gap on any side of the phone and pry  the case off with the plastic opening tool. Use moderate pressure to slowly maneuver the plastic opening tool around until the case is removed.
  • Find a gap on any side of the phone and pry the case off with the plastic opening tool.
  • Use moderate pressure to slowly maneuver the plastic opening tool around until the case is removed.
  • Take the case off with your fingers.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The green film is  located above the camera. It is the camera connector to the motherboard. Disconnect the camera connector with the plastic opening tool.
  • The green film is located above the camera. It is the camera connector to the motherboard.
  • Disconnect the camera connector with the plastic opening tool.
Agregar Comentario
Take a close up of the picture for this step for a better view. Use a plastic opening tool to disconnect the keyboard connector.
  • Take a close up of the picture for this step for a better view.
  • Use a plastic opening tool to disconnect the keyboard connector.
Agregar Comentario
The motherboard is held in place by the circular connector. Using a plastic opening tool, disconnect the circular connector.
  • The motherboard is held in place by the circular connector.
  • Using a plastic opening tool, disconnect the circular connector.
Agregar Comentario
A LCD connector is located underneath the motherboard. Lift the far edge of the motherboard gently upwards toward the center. Using a plastic opening tool, disconnect the LCD connector.
  • A LCD connector is located underneath the motherboard.
  • Lift the far edge of the motherboard gently upwards toward the center.
  • Using a plastic opening tool, disconnect the LCD connector.
Agregar Comentario
Lift the motherboard up with your fingers. Place the motherboard in a secure area.
  • Lift the motherboard up with your fingers.
  • Place the motherboard in a secure area.
Agregar Comentario
The antenna is the last part that needs to be removed. It is located at the bottom end of the device. Prop the antenna out with the plastic opening tool. Slip the tip of the tool in the edges of the antenna. Pry the antenna out with moderate pressure. Using a plastic opening tool, disconnect the connector leading from the phone to the antenna.
  • The antenna is the last part that needs to be removed. It is located at the bottom end of the device.
  • Prop the antenna out with the plastic opening tool. Slip the tip of the tool in the edges of the antenna. Pry the antenna out with moderate pressure.
  • Using a plastic opening tool, disconnect the connector leading from the phone to the antenna.
Agregar Comentario
The keyboard chip is located on top of the device. Pry the keyboard off of the case with  the plastic opening tool. The keyboard chip is located on top of the device. Pry the keyboard off of the case with  the plastic opening tool.
  • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
Agregar Comentario
Conclusión
Cameron Law
Miembro Desde 12/10/11
142 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 3-12, Regan Fall 2011 Miembro de Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 994
