Saltar al contenido principal
Samsung Galaxy Tab A 9.7 Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove one of the opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Disconnect the strip from the motherboard with the iFixit opening tool.
  5. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  6. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 6, imagen 2 de 2
    • Remove both side pieces using one of the the iFixit opening tools.
    • Lift up the headphone jack port with the iFixit opening tool as well.
  7. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Pull up the headphone jack port carefully and replace.
Conclusión
To reassemble your device, follow the instructions in reverse order.
2 personas más completaron esta guía.
Justin Osborn
Miembro Desde 04/09/19
154 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G3, Hovde Spring 2019 Miembro de IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 412
