Saltar al contenido principal
Samsung Galaxy Tab A 9.7 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Tab A 9.7  Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: paso 2, imagen 1 de 2 Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7  Battery Replacement: paso 3, imagen 1 de 2 Samsung Galaxy Tab A 9.7  Battery Replacement: paso 3, imagen 2 de 2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7  Battery Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab A 9.7  Battery Replacement: paso 4, imagen 2 de 2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7  Battery Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab A 9.7  Battery Replacement: paso 5, imagen 2 de 2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
Conclusión
13 personas más completaron esta guía.
Equipo
Cal Poly, Team S1-G3, Livingston Spring 2017 Miembro de Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Miembro
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 56
Todo El Tiempo: 11,103
