Introducción
Use this guide to replace the volume buttons.
Use the flat end of a metal spudger to pry the two plastic tabs near the dock connector off the rear case.
  • Use the flat end of a metal spudger to pry the two plastic tabs near the dock connector off the rear case.
Agregar Comentario
Remove the two 4.1 mm Tri-Wing screws near the adjacent edges of the dock connector.
  • Remove the two 4.1 mm Tri-Wing screws near the adjacent edges of the dock connector.
Agregar Comentario
The following steps will require you to disengage several clips (highlighted in red) around the perimeter of the rear case. The clips are delicate and fragile; proceed with caution.
  • The following steps will require you to disengage several clips (highlighted in red) around the perimeter of the rear case. The clips are delicate and fragile; proceed with caution.
Agregar Comentario
Disclaimer: The Galaxy Tab we acquired already had a shattered front glass panel. However, the procedure outlined in this guide is identical for both intact/shattered front panels. Insert a plastic opening tool near the bottom left edge of the rear case.
  • Disclaimer: The Galaxy Tab we acquired already had a shattered front glass panel. However, the procedure outlined in this guide is identical for both intact/shattered front panels.
  • Insert a plastic opening tool near the bottom left edge of the rear case.
  • Use your plastic opening tool to gently create a small gap between the front panel and the rear panel near the bottom left edge.
  • Run the plastic opening tool along the left side of the perimeter to create a bigger gap between the front panel and the rear panel.
  • Insert two guitar picks into the small gap created by the plastic opening tool.
Agregar Comentario
Insert the plastic opening tool into the dock connector and wedge it underneath the front panel/motherboard assembly. Thrust the plastic opening tool downwards to create a gap near the lower left corner of the front panel assembly.
  • Insert the plastic opening tool into the dock connector and wedge it underneath the front panel/motherboard assembly.
  • Thrust the plastic opening tool downwards to create a gap near the lower left corner of the front panel assembly.
  • Insert a guitar pick into the newly created gap near the lower left edge of the Galaxy Tab.
Agregar Comentario
Be careful when approaching the top left corner of the Galaxy Tab. Be sure to follow the next step carefully. When separating the front panel from the top left corner of the Galaxy Tab, be careful not to rip the microphone ribbon cable (highlighted in red in the first picture). It is extremely thin and easy to tear. Insert a plastic opening tool into the gap next to the left side of the guitar pick.
  • Be careful when approaching the top left corner of the Galaxy Tab. Be sure to follow the next step carefully.
  • When separating the front panel from the top left corner of the Galaxy Tab, be careful not to rip the microphone ribbon cable (highlighted in red in the first picture). It is extremely thin and easy to tear.
  • Insert a plastic opening tool into the gap next to the left side of the guitar pick.
  • Make sure to wedge it underneath the inner framework to gain the most leverage when releasing the clips.
  • Simultaneously lift upwards and run the plastic opening tool along the top left corner of the Galaxy Tab to free the Front Panel Assembly from the retaining clips.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Slightly lift the left side of the front panel assembly to separate it from its housing within the rear panel.
  • Slightly lift the left side of the front panel assembly to separate it from its housing within the rear panel.
  • Do not completely lift the front panel assembly, as it is still restrained to the rear panel by clips around the top, bottom, and right sides. Doing so may cause severe damage.
Agregar Comentario
Wedge the flat edge of an opening tool between the front panel and rear panel near the dock connector. Use a plastic opening tool to pry the bottom right corner out of its housing in the rear panel.
  • Wedge the flat edge of an opening tool between the front panel and rear panel near the dock connector.
  • Use a plastic opening tool to pry the bottom right corner out of its housing in the rear panel.
Agregar Comentario
Lift and remove the front panel assembly from the rear panel.
  • Lift and remove the front panel assembly from the rear panel.
Ok- what about replacing the touch screen glass that is shattered?
luffman - Contestar
Remove the single Phillips screw securing the battery to the motherboard.
  • Remove the single Phillips screw securing the battery to the motherboard.
Agregar Comentario
Use the edge of a plastic opening tool to pry the battery connector straight up off its socket on the motherboard.
  • Use the edge of a plastic opening tool to pry the battery connector straight up off its socket on the motherboard.
Agregar Comentario
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the motherboard.
  • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the motherboard.
Agregar Comentario
Lift and remove the rear camera from the Galaxy Tab.
  • Lift and remove the rear camera from the Galaxy Tab.
Agregar Comentario
Use the edge of a plastic opening tool to pry the volume buttons connector straight up from its socket on the motherboard.
  • Use the edge of a plastic opening tool to pry the volume buttons connector straight up from its socket on the motherboard.
Agregar Comentario
Insert the edge of a plastic opening tool in between the inner framework and the volume button recess. Carefully run the plastic opening tool to the left to dislodge the volume buttons assembly from the inner framework.
  • Insert the edge of a plastic opening tool in between the inner framework and the volume button recess.
  • Carefully run the plastic opening tool to the left to dislodge the volume buttons assembly from the inner framework.
Agregar Comentario
Remove the volume buttons assembly away from the Galaxy Tab.
  • Remove the volume buttons assembly away from the Galaxy Tab.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 11
Todo El Tiempo: 6,492
