Saltar al contenido principal
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: paso 1, imagen 2 de 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 2, imagen 1 de 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 4, imagen 3 de 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 5, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: paso 6, imagen 2 de 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
Conclusión
24 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-3, Remmell Fall 2015 Miembro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Miembros
12 Guías creadas
4 comentarios
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - Contestar
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - Contestar
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 46
Todo El Tiempo: 18,052
