Saltar al contenido principal
Samsung Galaxy Tab 4 7.0 Battery Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: paso 2, imagen 1 de 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: paso 3, imagen 1 de 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: paso 3, imagen 2 de 3 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: paso 3, imagen 3 de 3
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Conclusión
28 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-3, Remmell Fall 2015 Miembro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Miembros
12 Guías creadas
3 comentarios
This is for a cell phone, not a tablet. Why?
ckmjunk - Contestar
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 57
Todo El Tiempo: 26,603
