Saltar al contenido principal
Samsung Galaxy Tab 3 8.0 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Battery - Open up the tablet: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Battery - Open up the tablet: paso 1, imagen 2 de 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Back Cover: paso 2, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Back Cover: paso 2, imagen 2 de 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Battery: paso 3, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Battery: paso 3, imagen 2 de 2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove Battery: paso 4, imagen 1 de 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Speakers: paso 5, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect Speakers: paso 5, imagen 2 de 2
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: paso 6, imagen 1 de 3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: paso 6, imagen 2 de 3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Speakers: paso 6, imagen 3 de 3
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
  7. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect All Relays: paso 7, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Disconnect All Relays: paso 7, imagen 2 de 2
    • Using the plastic remover tool carefully unseat the four rectangular electric leads from the board. Each rectangle is a different size, the first one is large, the second one is medium, and the last two are small.
    • Using the plastic remover tool carefully unseat the square electric lead (marked in orange) from the board.
    • Using the plastic remover tool carefully unseat the small square and the two rectangular electric leads (marked in yellow) from the board.
  8. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: paso 8, imagen 1 de 3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: paso 8, imagen 2 de 3 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Unscrew Motherboard: paso 8, imagen 3 de 3
    • Unscrew the one 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
  9. Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove the Motherboard: paso 9, imagen 1 de 2 Samsung Galaxy Tab 3 8.0 Motherboard Replacement, Remove the Motherboard: paso 9, imagen 2 de 2
    • Carefully lift the board from the device.
Conclusión
12 personas más completaron esta guía.
Kyle Ballard
Miembro Desde 09/22/14
939 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 4-2, Brown Fall 2014 Miembro de USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Miembros
26 Guías creadas
2 comentarios
Be sure to include screw lengths to the nearest mm on all repair guides.
Dan Brown - Contestar
You don’t need to remove the battery in order to remove the motherboard. Just disconnect the battery!
matt greece - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 24
Todo El Tiempo: 11,054
