Saltar al contenido principal
Samsung Galaxy Tab 2 7.0 Camera Replacement
Qué necesitas
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: paso 2, imagen 1 de 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: paso 3, imagen 1 de 1
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Tab 2 7.0 Camera Replacement: paso 4, imagen 3 de 3
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: paso 5, imagen 1 de 1
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
Conclusión
2 personas más completaron esta guía.
Katija Tarailo
Miembro Desde 03/02/17
460 Reputación
3 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Spring 2017 Miembro de IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 662
