Saltar al contenido principal
Samsung Galaxy S5 Sport Screen Replacement
Qué necesitas
  1. Samsung Galaxy S5 Sport Screen Replacement, Battery: paso 1, imagen 1 de 3 Samsung Galaxy S5 Sport Screen Replacement, Battery: paso 1, imagen 2 de 3 Samsung Galaxy S5 Sport Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Screen Replacement: paso 2, imagen 1 de 3 Samsung Galaxy S5 Sport Screen Replacement: paso 2, imagen 2 de 3 Samsung Galaxy S5 Sport Screen Replacement: paso 2, imagen 3 de 3
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Screen Replacement, Screen: paso 3, imagen 1 de 3 Samsung Galaxy S5 Sport Screen Replacement, Screen: paso 3, imagen 2 de 3 Samsung Galaxy S5 Sport Screen Replacement, Screen: paso 3, imagen 3 de 3
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Screen Replacement: paso 4, imagen 1 de 2 Samsung Galaxy S5 Sport Screen Replacement: paso 4, imagen 2 de 2
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-6, Leahy Spring 2016 Miembro de USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 3,894
