Saltar al contenido principal
Samsung Galaxy S5 SIM Card Replacement
Qué necesitas
  1. Samsung Galaxy S5 SIM Card Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung Galaxy S5 SIM Card Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung Galaxy S5 SIM Card Replacement, Rear Case: paso 1, imagen 3 de 3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 SIM Card Replacement, Battery: paso 2, imagen 1 de 3 Samsung Galaxy S5 SIM Card Replacement, Battery: paso 2, imagen 2 de 3 Samsung Galaxy S5 SIM Card Replacement, Battery: paso 2, imagen 3 de 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
  3. Samsung Galaxy S5 SIM Card Replacement, microSD Card: paso 3, imagen 1 de 2 Samsung Galaxy S5 SIM Card Replacement, microSD Card: paso 3, imagen 2 de 2
    • Using a fingertip, pull the microSD card straight down out of its slot.
    • Remove the microSD card from the phone.
  4. Samsung Galaxy S5 SIM Card Replacement, SIM Card: paso 4, imagen 1 de 1
    • Repeat the above procedure to remove the SIM card.
Conclusión
34 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
465,777 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
3 comentarios
Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface.
Chris Ward - Contestar
"Use a Post-It Note's sticky backing to get a grip on the SIM card's smooth surface"
Good suggestion. Alternatively..........use a pencil eraser!
johnsg0053 - Contestar
Why is my galaxy s5s screen black..I can get the buttons to light up but the screen won't come on..
Misti Weatherwalk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 32
Ultimos 30 días: 172
Todo El Tiempo: 61,333
