Introducción
Is your phone not playing music correctly or at all? This guide will help your fix this problem by replacing the media speaker in your phone.
Locate the small slit on the bottom edge of the device between the back and front cases. Pop the back case off by inserting your finger and pulling the case away from the phone. If necessary (it shouldn't be), use the  Plastic Opening Tools to pry the back case off.
  • Locate the small slit on the bottom edge of the device between the back and front cases.
  • Pop the back case off by inserting your finger and pulling the case away from the phone.
Agregar Comentario
Remove the battery by pushing the bottom edge of the battery up and away from the phone If you would prefer, you may use the  Plastic Opening Tools for this step as well.
  • Remove the battery by pushing the bottom edge of the battery up and away from the phone
Agregar Comentario
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Agregar Comentario
Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe. Work carefully, and disengage all of the clips before removing the midframe. The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
  • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
Agregar Comentario
Slide the SD card out of its slot. Slide the SD card out of its slot.
  • Slide the SD card out of its slot.
Agregar Comentario
  • Locate the seven screws on the plastic casing.
  • Using the Phillips #00 Screwdriver, remove all seven screws.
    • Be careful not to lose any of these small screws.
Agregar Comentario
Once all seven screws have been removed, use the Plastic Opening Tools to gently release the plastic snaps around the seam of the black casing.
  • Once all seven screws have been removed, use the Plastic Opening Tools to gently release the plastic snaps around the seam of the black casing.
  • Be careful not to break any of the plastic snaps.
Agregar Comentario
After all the plastics snaps have been released, the black plastic casing will come off easily.
  • After all the plastics snaps have been released, the black plastic casing will come off easily.
  • Locate the speaker.
Agregar Comentario
Using the Plastic Opening Tools, carefully lift the golden-brown clamp holding down the speaker's ribbon cable.
  • Using the Plastic Opening Tools, carefully lift the golden-brown clamp holding down the speaker's ribbon cable.
  • Remove the speaker by gently pulling it.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 18-37, Regan Winter 2013 Miembro de Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 2,757
