Introducción
If your camera stops working or there are constant smudges or discoloration spots in your pictures, your camera lens may be broken or malfunctioning. Replace it by following these steps.
Locate the small slit on the bottom edge of the device between the back and front cases. Pop the back case off by inserting your finger and pulling the case away from the phone. If necessary (it shouldn't be), use the  Plastic Opening Tools to pry the back case off.
  • Locate the small slit on the bottom edge of the device between the back and front cases.
  • Pop the back case off by inserting your finger and pulling the case away from the phone.
Agregar Comentario
Remove the battery by pushing the bottom edge of the battery up and away from the phone If you would prefer, you may use the  Plastic Opening Tools for this step as well.
  • Remove the battery by pushing the bottom edge of the battery up and away from the phone
Agregar Comentario
Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
  • Remove SIM card by pushing down and away from the slot, then pulling it out toward the bottom edge of the phone.
Agregar Comentario
Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
  • Remove the seven 4.5 mm Phillips #00 screws along the perimeter of the phone.
Agregar Comentario
Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe. Work carefully, and disengage all of the clips before removing the midframe. The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
  • Staring near the power button, use a plastic opening tool to disengage the plastic clips securing the midframe.
    • Work carefully, and disengage all of the clips before removing the midframe.
  • The power button and the volume control button on the sides of the phone will fall out when the midframe is removed.
Agregar Comentario
Slide the SD card out of its slot. Slide the SD card out of its slot.
  • Slide the SD card out of its slot.
Agregar Comentario
  • Disconnect the ribbon cable and camera lens by tugging gently at the base of the ribbon cable either by pinching with fingers or with the Tweezers.
    • Only use the pinching method when the camera lens is already broken so as to avoid damage.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 18-37, Regan Winter 2013 Miembro de Cal Poly, Team 18-37, Regan Winter 2013
CPSU-REGAN-W13S18G37
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,302
