Introducción
Use this guide to replace the plastic midframe.
The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a  tool to best avoid breaking any clips along the perimeter of the rear case. Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
  • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
  • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
  • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Agregar Comentario
Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone. Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
Agregar Comentario
Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case. Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
Agregar Comentario
Pry along the top right side, and continue prying down the right side of the rear case. Pry along the top right side, and continue prying down the right side of the rear case.
  • Pry along the top right side, and continue prying down the right side of the rear case.
Agregar Comentario
Lift up and remove the rear case from the phone. You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  • Lift up and remove the rear case from the phone.
  • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
very easy to follow instructions clear and concise
Deric JONES - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to. Wedge a plastic opening tool into the small notch above the battery.
  • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
  • Wedge a plastic opening tool into the small notch above the battery.
  • Pry the battery up out of its recess.
Agregar Comentario
Remove the battery. Remove the battery.
  • Remove the battery.
Agregar Comentario
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click. After the click, release the card and it will pop out of its slot. For reassembly, push the SIM card into the slot until it clicks in place.
  • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
  • After the click, release the card and it will pop out of its slot.
  • For reassembly, push the SIM card into the slot until it clicks in place.
Agregar Comentario
Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it. Grasp and remove the SIM card away from the phone. Grasp and remove the SIM card away from the phone.
  • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
  • Grasp and remove the SIM card away from the phone.
Agregar Comentario
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click. After the click, release the card and it will pop out of its slot. For reassembly, push the microSD card into the slot until it clicks in place.
  • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
  • For reassembly, push the microSD card into the slot until it clicks in place.
Agregar Comentario
Use your thumb to slide the microSD card out of the slot. Remove the microSD card from the phone.
  • Use your thumb to slide the microSD card out of the slot.
  • Remove the microSD card from the phone.
Forgot about the step to remove the back casing...pretty simple though, just several screws then pop it off.
Courtney - Contestar
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
What would you use to remove the screws
Curt the heneke - Contestar
I used both P#000 and J#00 precision bits to good effect. I tend to prefer the Japanese Standard bits in place of Philips, as the JIS bits seem not to cam out and strip screws as easily.
E West -
Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone. The midframe lightly snaps in place, and can be removed with very little force.
  • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
  • The midframe lightly snaps in place, and can be removed with very little force.
There's another piece of the frame that needs to be taken out, but it doens't come out as nicely... unless I did something wrong. It's the part that covers the speaker. I couldn't find a nice way of taking it out.
David - Contestar
I had to use a guitar-pick to pry that section off of the frame. Start at the front-facing camera edge and run the pick underneath the plastic cover. The catches should release.
Takashi Alekseev - Contestar
I used a pointed prying too to get it started, then the flat one. It took some fiddling but finally came off nicely.
Nick B - Contestar
READ ME!
For a guide that takes you step by step on how to remove the SIM and microSD, I'm surprised they didn't mention the top part of this midframe (still attached, in the pictures). This top part of the midframe also needs to be removed before you can take out the motherboard.
You need to disconnect a ribbon not listed in these directions first, then pry that midframe up with the help of a guitar pick. This ribbon is located by the back-camera, next to the digitizer ribbon. This ribbon is connected to the midframe so it is essential you disconnect this before lifting the frame up.
The frame is really snapped in there so don't be afraid to use a little force - for reference, you will use more force to pull this frame off than you did to pull off the back-cover of the phone. Once this piece is off, your phone should look like the picture in step 14.
Jess - Contestar
Conclusión
35 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 13
Últimos 30 Días: 61
Todo El Tiempo: 39,391
