Saltar al contenido principal
Samsung Galaxy S II Micro-USB Port Replacement
Qué necesitas
  1. Samsung Galaxy S II Micro-USB Port Replacement, Micro-USB Port: paso 1, imagen 1 de 2 Samsung Galaxy S II Micro-USB Port Replacement, Micro-USB Port: paso 1, imagen 2 de 2
    • 1. Remove the rear casing and the battery.
    • 2. Remove the SD card and the sim card (if needed).
  2. Samsung Galaxy S II Micro-USB Port Replacement: paso 2, imagen 1 de 1
    • Use the Phillips screwdriver to remove the 7 Phillips head screws, indicated in the picture.
  3. Samsung Galaxy S II Micro-USB Port Replacement: paso 3, imagen 1 de 3 Samsung Galaxy S II Micro-USB Port Replacement: paso 3, imagen 2 de 3 Samsung Galaxy S II Micro-USB Port Replacement: paso 3, imagen 3 de 3
    • Move along the outside edge with the plastic tool, popping the connections to the phone.
    • The volume rocker and power button housing can be easily lost when you remove the back housing. Make sure you keep it where you can find it.
  4. Samsung Galaxy S II Micro-USB Port Replacement: paso 4, imagen 1 de 1
    • Remove the two black Phillips head screws located at the top left and the bottom right of the logic board.
  5. Samsung Galaxy S II Micro-USB Port Replacement: paso 5, imagen 1 de 1
    • Disconnect all push connectors and the antenna cable with a small pull shown on the left.
  6. Samsung Galaxy S II Micro-USB Port Replacement: paso 6, imagen 1 de 2 Samsung Galaxy S II Micro-USB Port Replacement: paso 6, imagen 2 de 2
    • Prop the motherboard on the side of the phone. Then take off the power button board (near the top of the antenna wire).
    • Remove the 2 Phillips head screws located at the bottom of the charging board.
    • Some models may have a ribbon flex button that sticks to the side of the phone, instead of one directly on the board. To remove, you must gently peel these from the sides of the phone using a thin spudger, otherwise the delicate ribbons may rip and you may not be able to power on your phone.
  7. Samsung Galaxy S II Micro-USB Port Replacement: paso 7, imagen 1 de 2 Samsung Galaxy S II Micro-USB Port Replacement: paso 7, imagen 2 de 2
    • Remove the board by prying off one end and moving toward the other.
    • A hair dryer can help loosen the adhesive, but it is optional.
  8. Samsung Galaxy S II Micro-USB Port Replacement: paso 8, imagen 1 de 2 Samsung Galaxy S II Micro-USB Port Replacement: paso 8, imagen 2 de 2
    • Replace the old board with a new one.
Conclusión
21 personas más completaron esta guía.
6 comentarios
Hi all,
I have a Samsung Galaxy S2. The USB charging port is not working reliably. I read this repair guide, got the part, and set about replacing the USB charging board. Unfortunately, when I opened the phone, it does not look like the photos in this guide. To start, there are six screws instead of seven. Then when the back is removed, there are not "two black screws" to be removed. Finally, the motherboard is completely different from what is shown here. It is one single board, with the USB charging port board incorporated. It cannot be removed to replace it. So the part I bought does not work with my Samsung Galaxy S2. Is there another guide to help with my model of this phone?
Model SGH-T989
Many thanks.
rileybk - Contestar
Hi rileybk, there are quite a number of phones called "Samsung Galaxy S2". Have a look at the Wikipedia here: https://en.wikipedia.org/wiki/Samsung_Ga...
The device shown here seems to be a SGH-I777 which you can read on the label below the battery.
As Wikipedia describes these devices can be very different from each other so that your replacement part might not fit or work at all.
(btw, I came by to look for a guide for the so-called "international version" i9100 ... I have to see whether this guide will help me nethertheless)
Steffan -
Need to buy new USBport and solder it to the motherboard, if there is no way to get new motherboard or replacement charging board.
ildafons - Contestar
Does this work with a Galaxy S2 with a model number of SPH-0710?
Gp Smith - Contestar
Whoops! I meant a a Galaxy S2 with a model number of SPH-D710.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 13,755
