Saltar al contenido principal
Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement
Qué necesitas
Resumen del Video
  1. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement, Rear camera & front camera & eapiece: paso 1, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement, Rear camera & front camera & eapiece: paso 1, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement, Rear camera & front camera & eapiece: paso 1, imagen 3 de 3
    • Remove SIM card tray.
  2. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 2, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 2, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 2, imagen 3 de 3
    • Remove S Pen.
  3. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 3, imagen 3 de 3
    • Remove back cover.
  4. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 4, imagen 2 de 2
    • Remove screws.
  5. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 5, imagen 3 de 3
    • Remove middle housing.
  6. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 6, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 6, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 6, imagen 3 de 3
    • Remove battery. But it's not necessary. You also can just release battery connector from motherboard.
  7. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 7, imagen 3 de 3
    • Release the connector on the board.
  8. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 8, imagen 2 de 2
    • Release the USB board connector on the back and remove the motherboard from front assembly.
  9. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 9, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 9, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 9, imagen 3 de 3
    • Remove rear camera.
  10. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 10, imagen 1 de 2 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 10, imagen 2 de 2
    • Remove front camera and noise-canceling mic.
  11. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 11, imagen 1 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 11, imagen 2 de 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 11, imagen 3 de 3
    • Remove earpiece assembly.
  12. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: paso 12, imagen 1 de 1
    • That's earpiece with sensors.
Conclusión
12 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,810 Reputación
62 Guías creadas
9 comentarios
Is there a way to replace the rear camera glass without remove the back cover?
Steve Tran - Contestar
Steve, I'm not sure if anyone told you yet, but yes. Using some pointed tweezers (CAREFULLY) you can pull the glass off. But, be very careful as the housing holding the glass can be damaged due to the tweezers.
Kelby -
Will the phone be able to operate as usual without both the rear and front camera?
Sean - Contestar
I accidently fell my phone into the water n my front camera is enter some water.Then ,I try to dry it by my hair dryer but my front camera is cover by distilled water.The front camera is working but it is blurry. How can I fix it?
jianshenphoon - Contestar
Please anyone, I have the same problem. Front cam is covered with oil. Any suggestion?
zerry yns -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 20,183
