Saltar al contenido principal
Samsung Galaxy Note 8.0 Headphone Jack Replacement
Qué necesitas
  1. Samsung Galaxy Note 8.0 Headphone Jack Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Headphone Jack Replacement, Battery: paso 4, imagen 1 de 2 Samsung Galaxy Note 8.0 Headphone Jack Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
  7. Samsung Galaxy Note 8.0 Headphone Jack Replacement, Headphone Jack: paso 7, imagen 1 de 2 Samsung Galaxy Note 8.0 Headphone Jack Replacement, Headphone Jack: paso 7, imagen 2 de 2
    • Remove the two 4.5-mm black phillips head screws using a #00Phillips screwdriver.
  8. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 8, imagen 1 de 2 Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 8, imagen 2 de 2
    • Gently pry up the teal connector.
    • Do not yank the connector. If it does not disconnect easily use a plastic opening tool between the connector and the board to lift the connector away from the board.
  9. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 9, imagen 1 de 2 Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 9, imagen 2 de 2
    • Gently pry up the gold connector.
  10. Samsung Galaxy Note 8.0 Headphone Jack Replacement: paso 10, imagen 1 de 1
    • Remove the headphone jack from it's housing.
    • If difficult, use a plastic opening tool to pry up.
Conclusión
6 personas más completaron esta guía.
Joel
Miembro Desde 09/23/14
1,862 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 12-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Miembros
16 Guías creadas
3 comentarios
Lightning struck while my son was on his tablet... no more headset audio? Replaced recommend parts still no audio. Plays fine without earbuds??? Insurance claim? What else could be the issue? Motherboard?
Shasta - Contestar
what are these connectors on the left side of headphone jack which are connected to the backside plate?
sanco - Contestar
this did not help getting the broken headphone jack out of my Samsung note 8
joshua- collins - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 6,809
