Saltar al contenido principal
Samsung Galaxy Note 8.0 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Note 8.0 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the Samsung S-Pen stylus.
    • Remove the micro SD storage card.
  2. Samsung Galaxy Note 8.0 Battery Replacement: paso 2, imagen 1 de 1
    • Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
  3. Samsung Galaxy Note 8.0 Battery Replacement: paso 3, imagen 1 de 1
    • Work your way around the entire device by carefully prying and sliding the plastic opening tool.
    • There are clips approximately 2cm apart. As you are removing the back cover you should hear the clips being dislocated from the tablet.
  4. Samsung Galaxy Note 8.0 Battery Replacement, Battery: paso 4, imagen 1 de 2 Samsung Galaxy Note 8.0 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the 8 Phillips#00 3-mm screws holding the battery in place.
  5. Samsung Galaxy Note 8.0 Battery Replacement: paso 5, imagen 1 de 1
    • Lift the top left corner of the battery up by the black tab.
  6. Samsung Galaxy Note 8.0 Battery Replacement: paso 6, imagen 1 de 1
    • Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
    • Do not yank the connector by the wires. If it does not disconnect easily, slide a plastic opening tool between the white connector and the board to lift the connector away from the board.
Conclusión
84 personas más completaron esta guía.
Joel
Miembro Desde 09/23/14
1,862 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 12-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 12-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G2
4 Miembros
16 Guías creadas
14 comentarios
Please help on the connector wire connections coz mine snapped and i dont know which which is supposed to be in place.. Will be waiting.. Thanks..
Narz Ferrariz - Contestar
Even me, 65 blond, woman made it thanks to your good guide. Thank you!!
elisabethbengzon - Contestar
This was a great help! I was able to replace my son's battery in 10 mins. I purchased the battery from eBay for only $8. Saved me a lot of money.
orchidsinjune0511 - Contestar
My Note would not turn on at all even though it was fully charged. Did not think it was on/off button so I followed the instructions for the Bios (reboot). Thought about it and had a program that was being fussy about turning off maybe causing an overload. These are very easy instructions to follow and better yet, it worked! My Note turned on and all is good with my world again. Learned that I really need to back up everything I have on my note. I reviewed all the instructions for the replacing of various parts and have to say the parts prices are more than reasonable. Thank you very much for having these instructions available to us novices.
Marcia Strickland - Contestar
I just wanna say thanks, the instructions were easy to follow. I'm left-handed so I had to turn my tablet in opposite directions to get the job done. I was very nervous messing with computer parts. Thanks again.
patricia Gibson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 33
Ultimos 30 días: 111
Todo El Tiempo: 98,951
