Saltar al contenido principal
Samsung Galaxy Note 3 Motherboard Replacement
Qué necesitas
  1. Samsung Galaxy Note 3 Motherboard Replacement, Remove the rear case: paso 1, imagen 1 de 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: paso 2, imagen 1 de 2 Samsung Galaxy Note 3 Motherboard Replacement, Remove Case from the Base: paso 2, imagen 2 de 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Motherboard Replacement, Battery: paso 3, imagen 1 de 2 Samsung Galaxy Note 3 Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Motherboard Replacement, S Pen: paso 4, imagen 1 de 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Motherboard Replacement, Unscrew Back Chassis: paso 5, imagen 1 de 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Motherboard Replacement, Remove Back Chassis: paso 6, imagen 1 de 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: paso 7, imagen 1 de 2 Samsung Galaxy Note 3 Motherboard Replacement, Screw Removal: paso 7, imagen 2 de 2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: paso 8, imagen 1 de 2 Samsung Galaxy Note 3 Motherboard Replacement, Unfasten Clips and Cable Connectors: paso 8, imagen 2 de 2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Motherboard Replacement, Motherboard Removal: paso 9, imagen 1 de 1
    • Pull up on the motherboard with tweezers.
Conclusión
74 personas más completaron esta guía.
Brittany Gail
Miembro Desde 09/23/14
8,504 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 2-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Miembros
25 Guías creadas
4 comentarios
I'm looking for the screws for this phone, but all the search hits I've come across are for the screwdriver. Any leads on where I can find the screws?
Jared Lunt - Contestar
I can replace motherboard sm-n9005 with motherboard sm-n900
yacine - Contestar
I want to replace motherboard of galaxy note 3 SM-N900 with SM-N9005. Is it possible and can it convert 3g to 4G. Because my phone doesn't support 4G .it is 3g and I want to make it 4G .what should I do help me
Nippy Preet -
I am also looking for the same question
Jalil Ahmad -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 47
Todo El Tiempo: 50,508
