Saltar al contenido principal
Samsung Galaxy Note 10.1 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: paso 1, imagen 1 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: paso 1, imagen 2 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Top Piece: paso 1, imagen 3 de 3
    • This is the back of the device and where you will begin to take it apart
    • It is neccesary to remove this piece first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: paso 2, imagen 1 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: paso 2, imagen 2 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Back Cover: paso 2, imagen 3 de 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: paso 3, imagen 1 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: paso 3, imagen 2 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing components covering battery: paso 3, imagen 3 de 3
    • Carefully remove all of the ribbons that connect over the battery.
  4. Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: paso 4, imagen 1 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: paso 4, imagen 2 de 3 Samsung Galaxy Note 10.1 Battery Replacement, Removing the Battery: paso 4, imagen 3 de 3
    • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
    • Disconnect the battery connector from the motherboard.
    • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
Conclusión
49 personas más completaron esta guía.
Tyler Salomone
Miembro Desde 09/22/14
1,020 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 3-7, Brown Fall 2014 Miembro de USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
3 Miembros
9 Guías creadas
13 comentarios
In Step 3, mention that you need to lift up on the black locks to take out the ribbons.
John Peterson - Contestar
Actually, on my device one lock was colored faun (beige). Lift them seen from the edge of the Note, not on the cable side.
dada64 -
Also, mention that you can disconnect the battery from the device by gently pulling out the battery and gently lifting up the wires.
This is not a plug to be pulled in the direction of the cables but vertically off the board. Putting it back in you simply plug the contacts down first, then the cable side of the plug.
dada64 -
When replacing the back cover, hook the bottom edge into the frame along the edge before trying to snap the rest in place along the sides.
charliesmallman55 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 100
Todo El Tiempo: 88,474
