Saltar al contenido principal
Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement
Qué necesitas
  1. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: paso 1, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: paso 2, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: paso 2, imagen 2 de 2
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
  3. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: paso 3, imagen 1 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: paso 3, imagen 2 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: paso 3, imagen 3 de 3
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
  4. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: paso 4, imagen 1 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: paso 4, imagen 2 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: paso 4, imagen 3 de 3
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
Conclusión
4 personas más completaron esta guía.
Joseph Rasico
Miembro Desde 02/20/17
2,173 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,626
