Saltar al contenido principal
Samsung Galaxy Note 10.1 2014 Battery Replacement
Qué necesitas
  1. Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: paso 1, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Battery Replacement, Case: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Battery Replacement: paso 3, imagen 1 de 1
    Phillips #000 Screwdriver
    $5.49
    Comprar
  4. Samsung Galaxy Note 10.1 2014 Battery Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Note 10.1 2014 Battery Replacement: paso 4, imagen 2 de 2
    Spudger
    $2.99
    Comprar
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
Conclusión
26 personas más completaron esta guía.
Joseph Rasico
Miembro Desde 02/20/17
2,173 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S1-G6, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 Miembros
6 Guías creadas
5 comentarios
Step 1 you have to show the back cover to remove. Showing the front side is confusing.
After step 4 there should be a step 5 to show how to disconnect the white connector with the colored wires: it took time to discover that you have to lift the 2 side clips, and not to pull…
prisca - Contestar
Just followed your instructions. Used a online kit with a guitar pick-like spudger. Had to wrestle with it slightly, but everything worked out perfectly to your instructions.
Matt - Contestar
You said it was like a guitar pick so I used a guitar pick. Worked pretty well. Guitar pick is bent up but they are cheap.
Stephen Nichols -
Followed the instructions. Worked nearly perfectly. The last step is a bit tricky. Just look at the new battery to understand the system.
Eramur - Contestar
Something I won’t be doing again. It was very annoying to do and nerve racking to complete. Was a pain to snap back together.
Bradley Carr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 30
Ultimos 30 días: 95
Todo El Tiempo: 21,736
