Introducción
This guide will show you how to get access to the motherboard of the Samsung Galaxy S so that you can remove and/or replace it.
Qué necesitas
To remove the back case of the Samsung Galaxy S, you may need a spudger.
Identify the slit which is at the bottom edge of the phone.
Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
Use the screwdriver to unscrew each of the 6 silver screws holding the main case to the LCD touchscreen.
If the screws are stuck, use the spudger to pry them out.
Using the plastic opening tool, you will need to detach the black square component which is boxed in blue.
Pry camera unit attached to it off the motherboard.
Use the plastic opening tool to disconnect the white wire boxed in red.
Carefully disconnect the green and golden boxed components from the motherboard.
2 personas más completaron esta guía.
