Introducción
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
  • Remove the back battery cover.
Agregar Comentario
Remove the phone's battery.
  • Remove the phone's battery.
Agregar Comentario
Remove six (4.28 x 1.25)mm screws.
  • Remove six (4.28 x 1.25)mm screws.
Agregar Comentario
Use the spudger to gently pry the silver plastic back plate from the body of the phone. Use the spudger to gently pry the silver plastic back plate from the body of the phone.
  • Use the spudger to gently pry the silver plastic back plate from the body of the phone.
Agregar Comentario
It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
  • Pull the antenna plug out of its socket.
Agregar Comentario
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out. Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out. Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Agregar Comentario
Pop the red hinged-release lever away from its ribbon. Then pull it out.
  • Pop the red hinged-release lever away from its ribbon. Then pull it out.
Agregar Comentario
Peel the button sensor on the side of the motherboard off of the case.
  • Peel the button sensor on the side of the motherboard off of the case.
Agregar Comentario
Slightly pull up one side of the motherboard. Pull the button/microphone plug out of its socket. Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  • Slightly pull up one side of the motherboard.
  • Pull the button/microphone plug out of its socket.
  • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
Agregar Comentario
You have successfully removed the motherboard from the phone.
  • You have successfully removed the motherboard from the phone.
Agregar Comentario
Conclusión
Kevin Huang
Miembro Desde 20/04/11
11 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-11, Regan Spring 2011 Miembro de Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,188
