Saltar al contenido principal
Samsung Epix Keyboard Replacement
Qué necesitas
  1. Samsung Epix Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Keyboard Replacement: paso 2, imagen 1 de 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Keyboard Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Keyboard Replacement: paso 5, imagen 1 de 2 Samsung Epix Keyboard Replacement: paso 5, imagen 2 de 2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Keyboard Replacement: paso 6, imagen 1 de 1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
  7. Samsung Epix Keyboard Replacement: paso 7, imagen 1 de 1
    • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully remove the ribbon.
  8. Samsung Epix Keyboard Replacement: paso 8, imagen 1 de 1
    • Remove the front faceplate.
  9. Samsung Epix Keyboard Replacement: paso 9, imagen 1 de 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
Conclusión
Una persona más ha completado esta guía.
Chris
Miembro Desde 04/20/11
23 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-15, Regan Spring 2011 Miembro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,657
