Saltar al contenido principal
Samsung Epic 4G Touch Battery Replacement
Qué necesitas
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Epic 4G Touch Battery Replacement, Rear Case: paso 1, imagen 2 de 2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: paso 2, imagen 1 de 2 Samsung Epic 4G Touch Battery Replacement: paso 2, imagen 2 de 2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: paso 3, imagen 1 de 2 Samsung Epic 4G Touch Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: paso 4, imagen 1 de 2 Samsung Epic 4G Touch Battery Replacement: paso 4, imagen 2 de 2
    • Lift and remove the battery from the midframe.
Conclusión
10 personas más completaron esta guía.
2 comentarios
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - Contestar
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 9,718
