Saltar al contenido principal
Samsung DVD-P230 LCD Screen Replacement
Qué necesitas
  1. Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: paso 1, imagen 1 de 3 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: paso 1, imagen 2 de 3 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: paso 1, imagen 3 de 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Samsung DVD-P230 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Samsung DVD-P230 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Unscrew the 3 screws in the back.
  4. Samsung DVD-P230 LCD Screen Replacement: paso 4, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Pull the outer case upward and then towards you.
  5. Samsung DVD-P230 LCD Screen Replacement: paso 5, imagen 1 de 3 Samsung DVD-P230 LCD Screen Replacement: paso 5, imagen 2 de 3 Samsung DVD-P230 LCD Screen Replacement: paso 5, imagen 3 de 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Samsung DVD-P230 LCD Screen Replacement: paso 6, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Samsung DVD-P230 LCD Screen Replacement, Power Cord: paso 7, imagen 1 de 3 Samsung DVD-P230 LCD Screen Replacement, Power Cord: paso 7, imagen 2 de 3 Samsung DVD-P230 LCD Screen Replacement, Power Cord: paso 7, imagen 3 de 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Samsung DVD-P230 LCD Screen Replacement, Tray: paso 8, imagen 1 de 3 Samsung DVD-P230 LCD Screen Replacement, Tray: paso 8, imagen 2 de 3 Samsung DVD-P230 LCD Screen Replacement, Tray: paso 8, imagen 3 de 3
    • Remove the three screws holding in the DVD tray
  9. Samsung DVD-P230 LCD Screen Replacement: paso 9, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Samsung DVD-P230 LCD Screen Replacement: paso 10, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement: paso 10, imagen 2 de 2
    • Gently lift the DVD tray off of the motherboard.
  11. Samsung DVD-P230 LCD Screen Replacement, Motherboard: paso 11, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement, Motherboard: paso 11, imagen 2 de 2
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  12. Samsung DVD-P230 LCD Screen Replacement: paso 12, imagen 1 de 3 Samsung DVD-P230 LCD Screen Replacement: paso 12, imagen 2 de 3 Samsung DVD-P230 LCD Screen Replacement: paso 12, imagen 3 de 3
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  13. Samsung DVD-P230 LCD Screen Replacement: paso 13, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement: paso 13, imagen 2 de 2
    • Lift board up and out of the lower case
  14. Samsung DVD-P230 LCD Screen Replacement, LCD Screen: paso 14, imagen 1 de 2 Samsung DVD-P230 LCD Screen Replacement, LCD Screen: paso 14, imagen 2 de 2
    • The LCD screen has pins attaching it to the motherboard. Flip the motherboard over.
    • De-solder LCD screen pins from the motherboard.
    • Pinch black tabs to remove LCD screen from motherboard.
    • Solder the new LCD screen pins into motherboard.
Conclusión
Una persona más ha completado esta guía.
Evan Domingue
Miembro Desde 01/28/11
410 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-30, Regan Winter 2011 Miembro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,985
