Introducción
Use this guide to remove the volume/scroll wheel.
Partes
No se requieren partes.
Hold the device with the screen facing away from you and the camera towards you. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover. Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  • Hold the device with the screen facing away from you and the camera towards you.
  • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Agregar Comentario
Place your fingers on both sides of the bottom of the battery and lift upwards. Pull the battery away from the phone.
  • Place your fingers on both sides of the bottom of the battery and lift upwards.
  • Pull the battery away from the phone.
Agregar Comentario
Place your thumb on the SIM card. Slide the card out of the slot. Slide the card out of the slot.
  • Place your thumb on the SIM card.
  • Slide the card out of the slot.
Agregar Comentario
Use the spudger to remove the rubber stoppers from the top of the cover. Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  • Use the spudger to remove the rubber stoppers from the top of the cover.
  • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Agregar Comentario
Use the spudger to loosen and separate the front and back covers. Pick up the back cover once loosened. The front and back covers will be attached to each other by a gold wire.
  • Use the spudger to loosen and separate the front and back covers.
  • Pick up the back cover once loosened.
  • The front and back covers will be attached to each other by a gold wire.
  • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Agregar Comentario
Use the screwdriver to unscrew the four screws that hold the scroll wheel in place. Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
  • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
Agregar Comentario
Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board. Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
  • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
  • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
Agregar Comentario
Conclusión
Kristin Manna
Miembro Desde 22/10/12
17 Reputación
10 Guías creadas
Equipo
Clemson, Team 14-4, Benson Fall 2012 Miembro de Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 347
