Introducción
If you want to remove or replace the outer glass or casing from the Samsung Blackjack II, you will need to disassemble the mobile phone. The Samsung Blackjack II (stylised as Blackjack II) is the commercial retail name for the Samsung SGH-i617, a smart phone that utilises the Windows Mobile 6 series operating system. If your outter glass has become dirty or damaged, you may want to take the device apart to clean or replace it.
Partes
No se requieren partes.
Slide the battery cover protector off.
  • Slide the battery cover protector off.
Agregar Comentario
Remove the battery.
  • Remove the battery.
Agregar Comentario
Unscrew the two screws just above where the battery was.
  • Unscrew the two screws just above where the battery was.
Agregar Comentario
Pop the two circular covers off from the top of the phone on the back. These are in the corners.
  • Pop the two circular covers off from the top of the phone on the back. These are in the corners.
Agregar Comentario
Unclip and pop off the front casing.
  • Unclip and pop off the front casing.
Agregar Comentario
Pop off screen glass from Your Blackjack II.
  • Pop off screen glass from Your Blackjack II.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
kat050483
Miembro Desde 31/07/12
157 Reputación
1 Guía escrita
Equipo
WRI115, Team 1-1, Ruszkiewicz SU 2012 Miembro de WRI115, Team 1-1, Ruszkiewicz SU 2012
WRI115-RUSZKIEWICZ-SU12S1G1
1 Miembro
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 248
