Introducción
This guide will be showing step-by-step instructions on how to get to and replace the motor of the airsoft gun.
Using a Phillips #0 screwdriver, remove the two 6mm screws located at the bottom of the hand grip. Slide the cover off.
  • Using a Phillips #0 screwdriver, remove the two 6mm screws located at the bottom of the hand grip.
    • Slide the cover off.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the motor out from the inside of the hand grip.
  • Pull the motor out from the inside of the hand grip.
  • Using a soldering iron and desoldering wick, desolder the wires from the motor.
Agregar Comentario
Using a soldering iron, solder the wires onto the new motor.
  • Using a soldering iron, solder the wires onto the new motor.
Agregar Comentario
Conclusión
Anika Morris
Miembro Desde 05/10/12
1 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-41, Regan Fall 2012 Miembro de Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 590
