Saltar al contenido principal
Roku XD 2050X Ethernet Port Replacement
Qué necesitas
  1. Roku XD 2050X Ethernet Port Replacement, Case: paso 1, imagen 1 de 3 Roku XD 2050X Ethernet Port Replacement, Case: paso 1, imagen 2 de 3 Roku XD 2050X Ethernet Port Replacement, Case: paso 1, imagen 3 de 3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Ethernet Port Replacement: paso 2, imagen 1 de 2 Roku XD 2050X Ethernet Port Replacement: paso 2, imagen 2 de 2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Ethernet Port Replacement: paso 3, imagen 1 de 3 Roku XD 2050X Ethernet Port Replacement: paso 3, imagen 2 de 3 Roku XD 2050X Ethernet Port Replacement: paso 3, imagen 3 de 3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Ethernet Port Replacement: paso 4, imagen 1 de 2 Roku XD 2050X Ethernet Port Replacement: paso 4, imagen 2 de 2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Ethernet Port Replacement: paso 5, imagen 1 de 1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Ethernet Port Replacement, Ethernet Port: paso 6, imagen 1 de 1
    • Desolder the 8 contact points.
    • For help with soldering view the iFixit soldering guide.
  7. Roku XD 2050X Ethernet Port Replacement: paso 7, imagen 1 de 1
    • Use pliers to pinch the two anchor points and gently press them through the board to separate ethernet port.
    • Remove the Ethernet port from board.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 1,099
