Introducción
This guide will help you remove the motor and requires the uses of a soldering iron. Check out this soldering guide for help if you don't know how to solder.
Qué necesitas
Twist the plastic lid counterclockwise to unlock it.
Lift the lid to remove it from the container.
Use a soldering kit to remove solder from the circuit board for the red wire.
Follow this soldering guide if you need extra help!
3 personas más completaron esta guía.
