Saltar al contenido principal
Revlon 473 Thermal Cutout Replacement
Qué necesitas
  1. Revlon 473 Thermal Cutout Replacement, Shell: paso 1, imagen 1 de 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Thermal Cutout Replacement: paso 2, imagen 1 de 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Thermal Cutout Replacement: paso 3, imagen 1 de 3 Revlon 473 Thermal Cutout Replacement: paso 3, imagen 2 de 3 Revlon 473 Thermal Cutout Replacement: paso 3, imagen 3 de 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: paso 4, imagen 1 de 1
    • Locate the thermal cutout under the coils of the heating element.
  5. Revlon 473 Thermal Cutout Replacement: paso 5, imagen 1 de 1
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
  6. Revlon 473 Thermal Cutout Replacement: paso 6, imagen 1 de 1
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
  7. Revlon 473 Thermal Cutout Replacement: paso 7, imagen 1 de 1
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
Conclusión
Jessica Leyva
Miembro Desde 09/18/12
143 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-5, Propen Fall 2012 Miembro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 10
Todo El Tiempo: 1,866
