Saltar al contenido principal
Replacing the Macintosh PowerBook 1400c Monitor
Qué necesitas
  1. Replacing the Macintosh PowerBook 1400c Monitor, Battery: paso 1, imagen 1 de 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Replacing the Macintosh PowerBook 1400c Monitor: paso 2, imagen 1 de 1
    • Slide the latch to the left to release the battery.
  3. Replacing the Macintosh PowerBook 1400c Monitor: paso 3, imagen 1 de 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Replacing the Macintosh PowerBook 1400c Monitor, CD-ROM Drive: paso 4, imagen 1 de 1
    • Locate the CD-ROM Drive latch.
  5. Replacing the Macintosh PowerBook 1400c Monitor: paso 5, imagen 1 de 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Replacing the Macintosh PowerBook 1400c Monitor: paso 6, imagen 1 de 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Replacing the Macintosh PowerBook 1400c Monitor, Keyboard: paso 7, imagen 1 de 1
    • Locate the speaker cover.
  8. Replacing the Macintosh PowerBook 1400c Monitor: paso 8, imagen 1 de 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Replacing the Macintosh PowerBook 1400c Monitor: paso 9, imagen 1 de 1
    • Gently lift the speaker cover to remove it.
  10. Replacing the Macintosh PowerBook 1400c Monitor: paso 10, imagen 1 de 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Replacing the Macintosh PowerBook 1400c Monitor: paso 11, imagen 1 de 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Replacing the Macintosh PowerBook 1400c Monitor: paso 12, imagen 1 de 1
    • Tilt the keyboard away from the screen.
  13. Replacing the Macintosh PowerBook 1400c Monitor: paso 13, imagen 1 de 1
    • Locate the six screws that secure the heatsink.
  14. Replacing the Macintosh PowerBook 1400c Monitor: paso 14, imagen 1 de 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Replacing the Macintosh PowerBook 1400c Monitor: paso 15, imagen 1 de 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Replacing the Macintosh PowerBook 1400c Monitor: paso 16, imagen 1 de 1
    • Remove the heatsink.
  17. Replacing the Macintosh PowerBook 1400c Monitor: paso 17, imagen 1 de 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Replacing the Macintosh PowerBook 1400c Monitor: paso 18, imagen 1 de 1
    • Detach the ribbon cable.
  19. Replacing the Macintosh PowerBook 1400c Monitor: paso 19, imagen 1 de 1
    • Remove the keyboard.
  20. Replacing the Macintosh PowerBook 1400c Monitor, Monitor: paso 20, imagen 1 de 1
    • Identify the right and left monitor end caps.
  21. Replacing the Macintosh PowerBook 1400c Monitor: paso 21, imagen 1 de 1
    • Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
  22. Replacing the Macintosh PowerBook 1400c Monitor: paso 22, imagen 1 de 1
    • Once the end cap has been loosened by the spudger, pull outwards on the end caps.
  23. Replacing the Macintosh PowerBook 1400c Monitor: paso 23, imagen 1 de 1
    • Completely remove both end caps.
  24. Replacing the Macintosh PowerBook 1400c Monitor: paso 24, imagen 1 de 1
    • Identify the 4 total screw under the end caps (2 under each end cap).
    • The two outside 16mm long screws
    • The two inside 5.4mm long screws
  25. Replacing the Macintosh PowerBook 1400c Monitor: paso 25, imagen 1 de 1
    • Lay the monitor all the way back.
  26. Replacing the Macintosh PowerBook 1400c Monitor: paso 26, imagen 1 de 1
    • Remove the 4 screws using the Phillips #0 screwdriver.
  27. Replacing the Macintosh PowerBook 1400c Monitor: paso 27, imagen 1 de 1
    • Identify the center cap of the monitor.
  28. Replacing the Macintosh PowerBook 1400c Monitor: paso 28, imagen 1 de 1
    • Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
  29. Replacing the Macintosh PowerBook 1400c Monitor: paso 29, imagen 1 de 1
    • Detach the center cap completely.
  30. Replacing the Macintosh PowerBook 1400c Monitor: paso 30, imagen 1 de 1
    • Identify the one 12.6mm long screw under the center cap.
  31. Replacing the Macintosh PowerBook 1400c Monitor: paso 31, imagen 1 de 1
    • Remove the center screw with a Phillips #0 screwdriver.
  32. Replacing the Macintosh PowerBook 1400c Monitor: paso 32, imagen 1 de 1
    • Lift upwards on the metal cover under the screw.
  33. Replacing the Macintosh PowerBook 1400c Monitor: paso 33, imagen 1 de 1
    • Completely remove the metal cover.
  34. Replacing the Macintosh PowerBook 1400c Monitor: paso 34, imagen 1 de 1
    • Identify where the left and right monitor cords are attached to the logic board
    • The base of the left monitor cord
    • The base of the right monitor cord
  35. Replacing the Macintosh PowerBook 1400c Monitor: paso 35, imagen 1 de 1
    • To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
  36. Replacing the Macintosh PowerBook 1400c Monitor: paso 36, imagen 1 de 1
    • Completely detach the left monitor cord from the logic board.
  37. Replacing the Macintosh PowerBook 1400c Monitor: paso 37, imagen 1 de 1
    • To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
  38. Replacing the Macintosh PowerBook 1400c Monitor: paso 38, imagen 1 de 1
    • Completely detach the right monitor cord from the logic board.
  39. Replacing the Macintosh PowerBook 1400c Monitor: paso 39, imagen 1 de 1
    • Completely remove the monitor from the computer.
Conclusión
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
5 personas más completaron esta guía.
Taylor Chris
Miembro Desde 04/01/11
187 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-39, Forte Spring 2011 Miembro de Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 4,174
