Introducción
This is a guide on how to replace the touch screen on a Palm Tungsten E.
Remove stylus and SD card. Using T-5 torx driver, remove 4 back panel screws.
  • Remove stylus and SD card.
  • Using T-5 torx driver, remove 4 back panel screws.
  • The screws are small and can be lost easily. Be sure to place them in a secure area.
Agregar Comentario
Begin to remove back cover by inserting the plastic opening tool under the usb and power input slots. Continue by sliding the plastic opener to the right at the markers shown until the cover releases. Continue by sliding the plastic opener to the right at the markers shown until the cover releases.
  • Begin to remove back cover by inserting the plastic opening tool under the usb and power input slots.
  • Continue by sliding the plastic opener to the right at the markers shown until the cover releases.
I think it's better to open from the right, not the left. The right will separate if you lever the metal back to the outside and push the plastic to the inside. The lft is more like a inge and would damage more easily.
Just my $0.02.
Yishai Sered - Contestar
Your device may not have a screen protector. If not, you do not need to complete step three. Please move on to step four. Remove screen protector by lifting hinge out of plastic housing.
  • Your device may not have a screen protector. If not, you do not need to complete step three. Please move on to step four.
  • Remove screen protector by lifting hinge out of plastic housing.
  • Remove top cover by gently pulling away from the device with plastic tool
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully remove motherboard from the standoffs without damaging the LCD flex connector. Using spudger( the black pencil-like tool shown in picture two), unlock both sides of the flex connector block (shown in the purple boxes in picture two) by pushing down.
  • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
  • Using spudger( the black pencil-like tool shown in picture two), unlock both sides of the flex connector block (shown in the purple boxes in picture two) by pushing down.
  • Remove motherboard completely.
  • Metal washers may pop out of the device during this step
Agregar Comentario
Remove buttons using fingers. Gently flex frame to release screen from plastic frame. Lift out screen.
  • Remove buttons using fingers.
  • Gently flex frame to release screen from plastic frame.
  • Lift out screen.
Agregar Comentario
Congratulations! You have successfully taken apart a Palm Tungsten E.
  • Congratulations! You have successfully taken apart a Palm Tungsten E.
Agregar Comentario
Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
  • Reassemble the device in the reverse order of the tear down using the new screen in place of the old screen.
  • To reconnect the flex connector press up on the blocks with the spudger to ensure they click into place.
  • Be careful not to damage the flex connector.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Kevin Hom
Miembro Desde 21/01/10
88 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-22, Maness Winter 2010 Miembro de Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 9
Todo El Tiempo: 5,061
