Introducción
This guide will demonstrate how to access the screen for removal and replacement on an IBM ThinkPad 560z.
Slide the battery release latch to the right.
  • Slide the battery release latch to the right.
  • Pull out the battery out towards the front of the device.
Agregar Comentario
Remove the plastic screw covers, then remove the 3 Phillips screws under them. Remove the plastic screw covers, then remove the 3 Phillips screws under them.
  • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off. Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
  • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
Agregar Comentario
Remove the four Phillips head screws.
  • Remove the four Phillips head screws.
Agregar Comentario
Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
  • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
Agregar Comentario
Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop. The connector is very fragile, so be careful. The connector is very fragile, so be careful.
  • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
John Allande
Miembro Desde 15/04/10
58 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 26-27, Regan Spring 2010 Miembro de Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 4,403
