Introducción
This guide describes how to fix the H02/H07 error that is common with Panasonic DVD/VCR players.
Partes
No se requieren partes.
With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Remove the screw that is on the right side of the panel facing you. Now rotate the device 180 degrees and remove the second screw.
  • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
  • Remove the screw that is on the right side of the panel facing you.
  • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
Agregar Comentario
Rotate the device so that the back faces you. With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  • Rotate the device so that the back faces you.
  • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Before removing top cover make sure that the back of the device is facing you.
  • Before removing top cover make sure that the back of the device is facing you.
  • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
Agregar Comentario
Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
  • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
  • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
  • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Nathan Cheadle
Miembro Desde 15/04/10
137 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 16-5, Maness Spring 2010 Miembro de Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Miembros
7 Guías creadas
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - Contestar
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 46
Últimos 30 Días: 225
Todo El Tiempo: 20,756
