Saltar al contenido principal
Repairing Vehicle Headliner
Qué necesitas
  1. Repairing Vehicle Headliner, Repairing Vehicle Headliner: paso 1, imagen 1 de 1
    • Prep the car for work.
    • Disconnect the negative battery terminal.
    • Removal of the right passenger seat may be necessary to help remove the headliner from the car.
    • Remove the trim.
    • Unbolt the sun visors, dome lamp, grab handles and any other accessories that are attached to the ceiling.
    • Remove the upper seat belt mounting loops.
    • Remove and/or pull back just enough of the side interior trim panels to gain access to the edge of the headliner. Complete removal of these panels is usually not needed.
    • Lower one side of the headliner panel and slide it over to clear the trim panels.
    • Turn the panel and remove it from the vehicle.
  2. Repairing Vehicle Headliner: paso 3, imagen 1 de 2 Repairing Vehicle Headliner: paso 3, imagen 2 de 2
    • Remove the old fabric from the board.
    • Place the headliner panel on a clean work table.
    • Carefully pull the old fabric material off the board. Usually the foam backing will remain stuck to the headliner board. Use a piece of the old material to rub the old foam loose from the board.
    • Vacuum the foam bits from the backing board.
  3. Repairing Vehicle Headliner: paso 4, imagen 1 de 3 Repairing Vehicle Headliner: paso 4, imagen 2 de 3 Repairing Vehicle Headliner: paso 4, imagen 3 de 3
    • Install new fabric:
    • If the board is damaged, repair it using aluminum tape. Any rough areas might show after the new fabric is applied.
    • Lay out the new fabric over the board. Pull 1/2 of it back over itself.
    • Spray headliner adhesive glue on 1/2 of the board and the back side of the fabric.
    • Carefully place the fabric onto the board starting from the center point and smooth it outward wit your hand as you lay it down.
    • Pull up the other 1/2of the fabric over the side you just glued down. Repeat the above steps to lay down this side of the fabric.
  4. Repairing Vehicle Headliner: paso 5, imagen 1 de 3 Repairing Vehicle Headliner: paso 5, imagen 2 de 3 Repairing Vehicle Headliner: paso 5, imagen 3 de 3
    • Trim up the fabric edges
    • Fold over the front & rear edges and glue them to the back side of the board about 1 inch from the edge.
    • Cut the side edges flush with the board. Also cut any access holes for the sun visors and other accessories that were previously removed.
  5. Repairing Vehicle Headliner: paso 6, imagen 1 de 3 Repairing Vehicle Headliner: paso 6, imagen 2 de 3 Repairing Vehicle Headliner: paso 6, imagen 3 de 3
    • Reinstall the headliner to the car:
    • Reverse the removal steps to re-install the headliner into the car.
    • Start one edge over the side trim panels and then raise the headliner into position over the other side trim panels.
    • Re-install the sun visors, dome lamp, seat belt upper loops and any other items that were previously removed
    • Lightly brush the headliner to remove marks & fingerprints.
    • If any of the trim clips break off of the interior trim panels, you can reattach them to the panel with 2-part epoxy glue.
Conclusión
16 personas más completaron esta guía.
HemiBill
Miembro Desde 05/30/12
3,092 Reputación
2 Guías creadas
3 comentarios
Excellent directions. I'd like to see a well made video of the procedure! Thanks,
Dub
bullfeather - Contestar
Thank you so much. I've never tried anything like this before, you've made it seem like even I can do it. I'm excited to save a cpl hundred by doing it myself!
Patti L Walton - Contestar
I like the steps you laid out. Its a very easy job of you have patience. Its a virtue in itself. All headliners are made different and from different material. Thank you for sharing this,
Michael Smith - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 29
Ultimos 30 días: 153
Todo El Tiempo: 81,828
