Do your printed papers have these or similar vertical black and yellow lines?
  • Do your printed papers have these or similar vertical black and yellow lines?
  • Then this is the tutorial for you to make them disappear
Agregar Comentario
Open the printer front and take everything out Take out the toners
  • Open the printer front and take everything out
  • Take out the toners
  • Take out the drum together with the waste bin
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Your printer should now look like in the image attached
  • Your printer should now look like in the image attached
  • Use a flashlight to see inside the printer
  • On the glossy black plastic you will see vertical lines of color which are the cause of your printers problem
Agregar Comentario
Use a small white paper and try to stick it into the top - like shown Move it from left to right and drag it out again You will see that it is pretty dirty afterwards
  • Use a small white paper and try to stick it into the top - like shown
  • Move it from left to right and drag it out again
  • You will see that it is pretty dirty afterwards
  • Do this multiple times and clean the black glossy plastic with a cotton cloth - be careful not to scratch it
Agregar Comentario
Close the printer again and print some pages
  • Close the printer again and print some pages
  • After the 2nd or 3rd the black vertical lines should be gone completely
  • Have fun - again!
Agregar Comentario
Conclusión
10 personas más completaron esta guía.
Michael Ionita
Miembro Desde 13/05/12
360 Reputación
1 Guía escrita
Michael I have a thick horizontal line that repeats as a Ghost image. Will this help fix it? I have tried cleaning the paper track and the rollers etc, with no such luck.
garthnathaniel - Contestar
same here, if i print a blank page it has various horizontal shadows and looks dirty
Kevin Voyson - Contestar
My printer was many years practically only B&W because of awful colors. This trick helped to restore colors. Thank you!
visitor visitor - Contestar
Step 4: you can also clean the bottom (and not only the top) of the black glossy plastic: it was the root cause of my black lines
Tested with CLX-3185FW
Thanks
Jean-Baptiste Beaufreton - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 9
Últimos 7 Días: 61
Últimos 30 Días: 303
Todo El Tiempo: 31,704
