Saltar al contenido principal
Repairing Polaroid Sun 600 LMS Gear Train
Qué necesitas
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: paso 1, imagen 1 de 2 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: paso 1, imagen 2 de 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: paso 2, imagen 1 de 1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: paso 3, imagen 1 de 1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Conclusión
5 personas más completaron esta guía.
Matthew Lessig
Miembro Desde 01/20/10
63 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-18, Maness Winter 2010 Miembro de Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Miembros
4 Guías creadas
3 comentarios
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Contestar
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 40
Ultimos 30 días: 71
Todo El Tiempo: 9,104
