Introducción
The scanner unit allows the user to scan documents onto their computer and/or copy and print original document.
Herramientas
Partes
No se requieren partes.
Locate data USB cable.
  • Locate data USB cable.
Agregar Comentario
Locate the end of the cable that plugs into the printer.
  • Locate the end of the cable that plugs into the printer.
Agregar Comentario
Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent. Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
  • Insert this cable end to the port in the leftmost edge behind the printer where there is a rectangular indent.
Agregar Comentario
Locate the USB end of the cable. Insert that end into your computer.
  • Locate the USB end of the cable. Insert that end into your computer.
Agregar Comentario
Turn wireless connection on your computer off and on. Sometimes doing this step is needed to have a connection.
  • Turn wireless connection on your computer off and on. Sometimes doing this step is needed to have a connection.
  • Check the network to make sure the computer and printer are connected to the same network.
Agregar Comentario
Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off. Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off. Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off.
  • Make sure "Demo Mode" is turned OFF. Locate LED control panel and select "Setup". From there locate "Demo Mode" and turn it off.
Agregar Comentario
  • Move the printer close to the router to ensure a strong connection.
Agregar Comentario
Make sure the transparent cover is clean. If not, wipe the glass screen with a polishing cloth. If there is still debris on the glass, try spraying it with a cleaning solution and wiping it again.
  • Make sure the transparent cover is clean. If not, wipe the glass screen with a polishing cloth. If there is still debris on the glass, try spraying it with a cleaning solution and wiping it again.
Agregar Comentario
If the print not is not clear, make sure the original document is flat on the glass. If the print out is still not clear, try finding a clearer version of your original document.
  • If the print not is not clear, make sure the original document is flat on the glass. If the print out is still not clear, try finding a clearer version of your original document.
Agregar Comentario
  • If above steps do not solve the problem, try re-installing the drive for the printer.
Agregar Comentario
Conclusión
Once your connection is set and that the screen is clear of any debris, you should be able to scan, copy and print documents.
Una persona más ha completado esta guía.
Raymond
Miembro Desde 15/01/13
42 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 18-38, Regan Winter 2013 Miembro de Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 784
