First, identify the piece of paper that is causing the jam.
  • First, identify the piece of paper that is causing the jam.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use your hand to remove the jammed piece of paper. Pull until the paper is out. Use your hand to remove the jammed piece of paper. Pull until the paper is out. Use your hand to remove the jammed piece of paper. Pull until the paper is out.
  • Use your hand to remove the jammed piece of paper. Pull until the paper is out.
Agregar Comentario
Do not reuse the piece of paper that caused the jam. Replace the paper with fresh, uncrinkled  paper.
  • Do not reuse the piece of paper that caused the jam. Replace the paper with fresh, uncrinkled paper.
Agregar Comentario
Conclusión
Tim Wise
Miembro Desde 01/04/11
170 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-38, Forte Spring 2011 Miembro de Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 6
Todo El Tiempo: 3,685
