Introducción
This guide will instruct you on how to remove the fan blade and transformer.
Partes
No se requieren partes.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
Agregar Comentario
Pull the front and back cover apart.
  • Pull the front and back cover apart.
  • Be careful not to pull the front cover off completely because it holds the wires.
Agregar Comentario
Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
  • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
  • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
  • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
  • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
Agregar Comentario
Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you  may damage circuit elements. Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
  • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
  • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Agregar Comentario
In order to remove the fan blade pliers were used to remove the holding nut. After the holding nut is loose, use the pliers to pull up to remove the nut.
  • In order to remove the fan blade pliers were used to remove the holding nut.
  • After the holding nut is loose, use the pliers to pull up to remove the nut.
Agregar Comentario
Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
  • Remove the two bronze Phillips 29-mm bolts that hold the fan blade to the transformer.
  • Use a pair of pliers to hold the nut at the bottom of the transformer, as you unscrew from left-to-right at the top of the transformer. After, pull up and remove both the screw and nut.
Agregar Comentario
Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer. Remove screws by pulling them away from the base.
  • Next, remove the two silver Phillips (8-mm head) 40-mm screws from the transformer.
  • Remove screws by pulling them away from the base.
  • The transformer should be free after this step.
Agregar Comentario
Conclusión
Mateo Begue
Miembro Desde 26/09/12
78 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-46, Forte Fall 2012 Miembro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 6
Últimos 30 Días: 24
Todo El Tiempo: 2,532
