Introducción
In many devices such as handheld phones, the buttons necessary to operate the device will malfunction. This guide will show you how to access the rubber keypad in a step-by-step manner in order to determine what is malfunctioning with the keypad. If the keypad is damaged, this guide will show you how to remove the keypad from the housing.
Qué necesitas
Orient the phone so that the phone model and other descriptive information is facing upward.
Locate the two silver screws near the hinge where the battery is housed.
Remove the silver screws using a Phillips head #2 screwdriver.
Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
