Saltar al contenido principal
Removing the HP Compaq dx2000MT Optical (CD) Drive
Qué necesitas
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: paso 1, imagen 1 de 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 2, imagen 1 de 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 2, imagen 2 de 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 3, imagen 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 3, imagen 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 3, imagen 3 de 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 4, imagen 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 4, imagen 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 4, imagen 3 de 3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: paso 5, imagen 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: paso 5, imagen 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: paso 5, imagen 3 de 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 6, imagen 1 de 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 6, imagen 2 de 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 7, imagen 1 de 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 7, imagen 2 de 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 8, imagen 1 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 8, imagen 2 de 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: paso 8, imagen 3 de 3
    • Remove the optical drive by sliding it out the front of the device.
Conclusión
Logan Pace
Miembro Desde 10/12/11
2,224 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 17-16, Regan Fall 2011 Miembro de Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,468
