Saltar al contenido principal
Removing the Dell Inspiron 1150 Display Assembly
Qué necesitas
  1. Removing the Dell Inspiron 1150 Display Assembly, Removing Dell Inspiron 1150 Battery: paso 1, imagen 1 de 3 Removing the Dell Inspiron 1150 Display Assembly, Removing Dell Inspiron 1150 Battery: paso 1, imagen 2 de 3 Removing the Dell Inspiron 1150 Display Assembly, Removing Dell Inspiron 1150 Battery: paso 1, imagen 3 de 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Display Assembly, Hard Drive: paso 2, imagen 1 de 2 Removing the Dell Inspiron 1150 Display Assembly, Hard Drive: paso 2, imagen 2 de 2
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): paso 3, imagen 1 de 3 Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): paso 3, imagen 2 de 3 Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): paso 3, imagen 3 de 3
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. Removing the Dell Inspiron 1150 Display Assembly, Keyboard: paso 4, imagen 1 de 3 Removing the Dell Inspiron 1150 Display Assembly, Keyboard: paso 4, imagen 2 de 3 Removing the Dell Inspiron 1150 Display Assembly, Keyboard: paso 4, imagen 3 de 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  5. Removing the Dell Inspiron 1150 Display Assembly: paso 5, imagen 1 de 3 Removing the Dell Inspiron 1150 Display Assembly: paso 5, imagen 2 de 3 Removing the Dell Inspiron 1150 Display Assembly: paso 5, imagen 3 de 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  6. Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: paso 6, imagen 1 de 3 Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: paso 6, imagen 2 de 3 Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: paso 6, imagen 3 de 3
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  7. Removing the Dell Inspiron 1150 Display Assembly: paso 7, imagen 1 de 3 Removing the Dell Inspiron 1150 Display Assembly: paso 7, imagen 2 de 3 Removing the Dell Inspiron 1150 Display Assembly: paso 7, imagen 3 de 3
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
Conclusión
2 personas más completaron esta guía.
Daniel
Miembro Desde 04/25/10
87 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 16-2, Maness Spring 2010 Miembro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 6,872
